Malvern Tramway Substation
Malvern Tramway Substation is a rotary converter station producing 600 Volt Direct Current supply for the tramway system. It is virtually complete including AC switchgear, two 1000 kW rotary converters together with their control equipment, DC switchboard and rotary converter repair facilities. The station was commissioned in 1929 and retired in the late 1990s.
It is believed that the Malvern rotary converter traction substation has survived with its plant virtually complete due to the lateness of its retirement and the fact that replacement traction power semi-conductor rectifier substations were sited elsewhere. There evidently being no pressing need to either re-use the substation building or its site for other purposes.
| Marker Type | Engineering Heritage National Marker (EHNM) |
| Award Date | June 2016 |
| Heritage Significance | The essentially complete rotary converter substation plant and equipment that from 1930 to the 1990s
supplied 600 volt direct current (DC) for electric trams. The key items are the two 1000 kW English Electric rotary converter machines, associated 6.6 kV switchgear, transformers, automatic starting and AC control gear and DC switchgear/switchboard. |
Virtual interpretation site. There was no unveiling ceremony. |
| Plaque/Interpretation Panel | Not Installed. |
