Humphrey Pumps, Cobdolgla, Murray River
Developed and patented by English engineer Herbert Alfred Humphrey, these pumps were chosen for the Cobdogla irrigation scheme because they made the most efficient use of the available timber fuel. The pumps ran on gas produced from wood (producer gas) in a plant designed by W F Saunders AMIEAust and built by May Brothers of Gawler.
The pumps were designed and built by the Scottish firm of William Beardmore and were the only two of their kind installed in the Southern Hemisphere. They supplied irrigation water between 1927 and 1965.
In 1986 The Engineering and Water Supply Department completed the restoration of what is now the world’s only working Humphrey pump.
In 2010 the pumps were awarded an Engineering Heritage National Landmark. With a new category of Marker available, the installation was reclassified as an Engineering Heritage International Marker in 2015.
Humphrey Pumps, Cobdolgla, location map.
Marker Type | Engineering Heritage National Marker (EHNM) |
Award Date | 2010 |
Marker Type | Engineering Heritage International Marker (EHIM) |
Award Date | 2015 |
Heritage Significance | The pump works with high efficiency and strength without the use of any rotating flywheel, solid piston, connecting rod, rotating crank or bearings of any kind. The pumps work essentially as a four stroke engine, with water as the moving piston. It is the simplicity and elegance of the design which makes it so unique. |
Nomination Document | Available here. |
Ceremony Booklet | Not Available. |
Interpretation Panel | None Installed. |
